Case 600 propane
Dennis Stoeser
02-06-2005 19:45:48
Where do I find the serial number for a 600? The book says they only built 350. Is this to rare of a tractor to convert to gasoline?
Dennis Stoeser
02-07-2005 19:59:51
 Re: Case 600 propane in reply to Dennis Stoeser, 02-06-2005 19:45:48
Sounds like maybe I should leave it alone and original. Check the ads as I think I will sell it and concentrate on my 40 "D" standard with the early style fenders. Thanks for the input.
caseman-d
02-06-2005 20:12:40
Not sure where the serial number tag is on a LP, but the serial number should also be on the engine flange LH side by the air cleaner. I have heard of people conveting the 910 to a carberated engine using a carb off a 930 gas. Not everyday one can say they hace a Case 600 with a 377 gas in it. Go for it.
caseman-d
mike's600
02-07-2005 16:42:40
 Re: Case 600 propane in reply to caseman-d, 02-06-2005 20:12:40
Hey, caseman-d , i got one on gas, it is a real looker. People who know Case tractors stop and do a double take. I"am running a LA Carb, but she"s straving for gas towards the end of the pull!
There should be a steel I D plate on the fender support on the right side sitting on the tractor.That number should match the stamp on the engine block.
Tom Flecken
02-07-2005 19:32:14
 Re: Case 600 propane in reply to mike's600, 02-07-2005 16:42:40
NO, NO don"t convert that tractor to gas, if you need parts i can get them for you, thats a rare tractor and you should keep it that way, i own a case 900 L-P
Mallard
02-12-2005 08:25:13
 Re: Case 600 propane in reply to Tom Flecken, 02-07-2005 19:32:14
Tom
I have 900 LP. Looking for regulator kit. Can you help.
Mallard
