Well I went over last week and had it running in under 10 minutes. She fired off wide open throttle. Two or three times till I disconnected the gummed up govenor shaft. Then settled into a nice purr. Of course I had disconnected the fuel line and flushed some fresh gas through the carb. Then used the same squirt can to fill the bowl rather than rely on any fuel(?) in the tank. I noticed that the pitman arm was pointing in the air where it was supposed to point down and when I turned the steering wheel to the right the wheels went left. I imagine it had caught one of the runts in the yard and just about removed someones had when it spun that fast and far, or had been fixed by someone and put back together wrong. Anyway as soon as I jumped aboard and tried to start it in gear with the clutch pushed in to see if it was free, the starter jammed in the flywheel and every thing locked up. Not having a socket set with me I just left it till today. Now this morning I gathered together my buddy's Fully loaded F250HD 4X4 and 60-70 feet of chains. I hooked the chain around the front edge of the right front wheel to get them pointed in my direction (as viewed in above pic) dropped it in 2WDlow (4wd without the hubs locked) and pulled the wheel right off of it. Spindle and all. It didn't even budge!, as it resides in it's own little holes and ruts in the yard. Guess I'll have to try and get something near to it than can lift and drag it out of there and onto a trailer. The saga will cointinue..... ..... ...
