Case L Camshaft
Kasey
02-06-2005 19:07:42
I have just removed the cam from my old model L. All four exhaust lobes are quite rounded as though they are severely worn but they all measure out to have identical lift, which suggests they are supposed to be rounded. The intake lobes are quite pointed and also measure identical lift with each other. The cam followers for all lobes show little to no wear. Can someone tell me if I have a worn cam or a normal one?
Allanc
02-06-2005 22:12:30
 Re: Case L Camshaft in reply to Kasey, 02-06-2005 19:07:42
How old an L? I suspect you have worn lobes, but they may have changed the grind. I know other makes that played with rounded lobes.
