Ever build a 3 point for a Case DC?
Jonathan Anders
02-06-2005 18:56:19
While I was working on my DC today, I was looking at how a person might make a three point for it. I was thinking your draft arms could come off the old cultivator brackets on the rear axle, with an adjustable sway control arm from same bracket to draft arm. The original hydraulic cultivator lift could push a rod forward to a fulcrum pivot mounted above the axle, with a lift link going down to the draft arms. The same set up would work on each side of the tractor. I didn't look at where a center link could come from, but if I spend time making all this other stuff from scratch, I suppose I could fabricate a bracket for that as well. I hope I described it well enough. My problem is I can see all sorts of things in my mind, but have limited fabrication skills. What do you guys think? Ever see one someone else has made?
Jerry W
02-07-2005 08:50:39
 Re: Ever build a 3 point for a Case DC? in reply to Jonathan Anders, 02-06-2005 18:56:19
I haven't for a DC but I built a 3 point for one of my VAC's. It would be nice if you had the rear end with the cast in lugs for the OEM set up. Anything is possible with a little imagination but that can be a dangerous thing as well.
Jerry
JC CASE
02-07-2005 16:09:42
 Re: Ever build a 3 point for a Case DC? in reply to Jerry W, 02-07-2005 08:50:39
Jerry, do you have any specs. and pics. of this. I'm working on my VAC 3 point.
Thanks JC
