580c backhoe
Randy A
02-06-2005 15:39:02
When driving my 580c in 4th I smell clutch and start slowing down wile going up a hill, in third it is not nearly as bad. Is this adjustable or is it new clutch time? Also what is the weight of this machine? Thanks
george md
02-06-2005 16:29:43
 Re: 580c backhoe in reply to Randy A, 02-06-2005 15:39:02
Randy,
It's more likely the brakes you smell, back off the adjustments when you travel on the road. Seems that
they get tighter as they heat from high speed.
I have had the same problem on 580 B and 580 super D.
george
Randy A
02-06-2005 18:33:49
 Re: 580c backhoe in reply to george md, 02-06-2005 16:29:43
Would the loosing power and slowing down while going up a hill be related to the torque converter then?I have seen posts talking about changing the fluid and filter, am I on the right track? thanks
MickK
02-07-2005 15:28:53
 Re: 580c backhoe in reply to Randy A, 02-06-2005 18:33:49
If it has a torque converter then it could be slipping.
Remember these thing weight a lot. My D is about 6500kg. Thas a sh&^t load of weight to get up a hill.
I can only get up the hills in my backyard in first.
Get the rpm up to around the 2200 mark for full converter lockup. These engines can handle the rpm easily.
As to the smell, well yes, the oil will be getting hot and the springs will probably be suffering under the load.
Changing the oil never hurt, especially if you have not done it yet.
MickK
