VAC Question
Gary from Iowa
02-06-2005 14:23:50
On a Case Model VAC (1951) Is there suppose to be a clamp, or a bracket between the Exhaust Manifold Elbow and the Air Cleaner. The exhaust elbow on mine has the two holes molded in the elbow, but does not look like one was ever used. My Model S has one, but not sure if a VAC had one or not. Have books on all my other tractors, but no parts book for a VAC. Thanks for any help.
F-I-T
02-06-2005 15:25:12
 Re: VAC Question in reply to Gary from Iowa, 02-06-2005 14:23:50
third party image
Hi gary:
Like you, I could not find the proper bracket that fit between the exhaust elbow and the air pipe. I fabricated on from flat stock and a half circle of muffler pipe stock. It works really well to stabilize the air pipe.
Frank
mj
02-07-2005 19:28:08
 Re: VAC Question in reply to F-I-T, 02-06-2005 15:25:12
I've got an extra or two.
Joe (Wa)
02-06-2005 15:22:34
Yeah a 2 piece clamp with 4 bolts old pn VT4857 newer p/n A30902. Probably discontinued by Case, they show up on ebay occasionally. I am sure that Don L and others here can provide.
Joe
Gary from Iowa
02-06-2005 17:17:54
 Re: VAC Question in reply to Joe (Wa), 02-06-2005 15:22:34
Thanks guy's. I know that Don L has them, but did not know if they were for the S series and the VA series both. I guess I should have applied some common sense, as my exhaust elbow has the bolt pattern for one. However, sometimes common sense does not apply to these older tractors. Hey, Frank your picture really shows up great. You better patent that bracket. Looks good.
F-I-T
02-06-2005 17:34:13
 Re: VAC Question in reply to Gary from Iowa, 02-06-2005 17:17:54
Thanks Gary. I have one that was for an SC but could never get it to fit and line up. You can probably search and find some of those pictures when I was trying to get it right.
This one works nice. I painted the area Flambeau Red where it aligns with the pipe, and Heat Resistant Stainless Steel (Eastwood) where it is out in the open to the elbow.
It looks pretty good.
