Case 311 horsepower and battery
railroadgoat
02-06-2005 10:41:18
311 listed in photo ads for sale, but have questions. Model 311 what kind of horsepower ?? Battery, 6 volt or 12 volt, positive or negative ground. How do I engage side belt pulley ?? Any secret to operating the 3 point hitch, lever to engage or just check hydraulic fluids ?? 90 wt ?? Lever on left side of bellhousing resembles shuttle lever, what is it ??
Case300
02-06-2005 13:54:36
 Re: Case 311 horsepower and battery in reply to railroadgoat, 02-06-2005 10:41:18
Looked at tractor it is a '57 round nose. the sheet metal does look good, worth half the value.
Tires look poor, says it runs with out smoke, would ask for more pictures. The hydraulic system takes 12 qts of 10W-30 all seasons, the transmissions holds 24 qts. 90W. Wide front end also desirable for most buyers. Little far for me to look at-it's in California- only time I went that far from Maryland was on my way to Korea in 1953.
Joe (Wa)
02-06-2005 12:41:27
1957 311. 148 cid engine rated 29 drawbar & 33 pto. Original was 6 volt positive gnd. Original had a Eagle hitch, factory oil was 10 wt motor oil. Most people use hydraulic oil nowadays. Lever on the side is hand clutch per Lincoln's post. Transmission is 4 speed, may have the optional triple range. Original side pulley is flat belt, engaged/disengaged by sliding pulley drive in/out of gear mesh, set screw clamps in place.
Joe
railroadgoat
02-06-2005 13:16:53
 Re: Case 311 horsepower and battery in reply to Joe (Wa), 02-06-2005 12:41:27
311 Round Nose I think Serial # 607---. I think it is a 1958 at a steal. I can't beleive it isn't gone by now. I priced it so hauling could be taken into consideration on total.
Joe (Wa)
02-06-2005 14:21:53
 Re: Case 311 horsepower and battery in reply to railroadgoat, 02-06-2005 13:16:53
The 1958 version of the 311 was the 311B starting serial nr 5095001. Pretty much the same tractor with squared off sheet metal, grill, & bolster, headlights are in the front on the grill cap. The 311 in the add is a roundnose, head lights are missing.
John H-WI
02-06-2005 12:35:10
Are you talking of the round nose 300 or the "B" series? Ours never had a pulley on it, didn't have a use for one. Round nose rated at 34.6 hp. Great little tractor. We pulled 3-14's with ours.
Lincoln
02-06-2005 11:33:20
If you are close enough to that tractor for $1500 I'd buy if first and ask questions later.
Lincoln
02-06-2005 11:22:54
They were origionally six volt. The lever on the left is a transmission clutch that lets you stop forward movement of the tractor but keeps the PTO running. The three point or eagle hitch operates with a lever like any other set up. I use hydraulic oil in mine. Never had a belt pulley so I can't help you there.
