D verses DC
Pastor John
01-10-2006 15:21:26
I am considering the purchase of a early model D Case with a wide front end. I'm not sure of the age I only know it has a 6 volt system without lights, generator and hydralics.
I would be using it on tractor rides and parades.
My question is this: Is this basically the same tractor as the DC which I am more familiar with? The reason I'm asking is weight and restoration costs (tires etc)are a consideration.
Thanks for your help
CK RICHARD
01-11-2006 16:23:07
 Re: D verses DC in reply to Pastor John, 01-10-2006 15:21:26
Do you like to ride up high or down low ? Of all the case tractors in my family my oldest son likes to drive his Pops D evem over his own VA. I like riding up high. they both look great and are fun to drive the D is ez to get on and off .
Gene Dotson
01-10-2006 15:35:25
The D and DC are basically the same tractor. The D is the standard version of the DC. Primary differences are the low seating position and non adjustable tread wheels. The D uses 26 inch rear tires which are hard to come by and expensive. Rear wheels do not have adjustable axles.All sheet metal, engine and mechanical parts are the same... Gene
dctom
01-10-2006 16:46:59
 Re: D verses DC in reply to Gene Dotson, 01-10-2006 15:35:25
gene, lot of older combines used 26 inch tires easy to get if you have combine salvage yard near by tom
Gene Dotson
01-10-2006 19:16:31
 Re: D verses DC in reply to dctom, 01-10-2006 16:46:59
14.9X26 were common on a lot of combines and will work well on a D. I am still trying to find a decent 13.6X26 tire for my "S". I can't use the 14.9X26 due to the close fit with the belt pulley. I found 1 combine in searching 3 different yards with 13.9 tires and it had set flat for at least 15 years... Gene
dctom
01-10-2006 15:28:21
they are the same tractor preacher, just diferent size tires
Tuggle
01-10-2006 15:42:33
 Re: D verses DC in reply to dctom, 01-10-2006 15:28:21
The D has bigger fenders too.
Gene Dotson
01-10-2006 19:18:51
 Re: D verses DC in reply to Tuggle, 01-10-2006 15:42:33
The D was also available with clamshell fenders, but most were the western style... Gene
