830 starting problem
kevin in va
02-04-2005 19:25:55
hooked charger up wrong on 6 volt batteries.replaced batteries;still not starting;what did i fry or where does my problem lie? thanks
chess
02-05-2005 07:22:32
 Re: 830 starting problem in reply to kevin in va, 02-04-2005 19:25:55
forgot to tell you also to check that you are gettink current to solenoid when you turn key. that part could be bad.
c hess
02-05-2005 07:18:09
i assume starter is not turning motor? i would take solenoid on top of starter apart {very carefully- do not twist small screws as you might breake wire off)you can then turn round large washer around or just polish an clean allparts. you will find i screw (contact)will beburnedan will probably not be making contact. turn that screw half turn an you will be good as new!
