john saeli---clutch issue
DWhittemore
02-04-2005 13:27:58
mr.saeli,could it be that when I engage clutch that it sticks to the flywheel? could it be that is why the rear wheels dont roll when clutch is engaged.Thanks Dennis /fla
John Saeli
02-04-2005 16:57:57
 Re: john saeli---clutch issue in reply to DWhittemore, 02-04-2005 13:27:58
Hey Dennis: Do you mean it won't roll when Disengaged? If it won't roll when Disengaged, but in gear,& the engine won't turn over, 1. Engine seized or 2. Too low a gear, 3rd or 4th should roll it over 3. Clutch Facing seized to the flywheel
Dwhittemore
02-04-2005 17:41:52
 Re: john saeli---clutch issue in reply to John Saeli, 02-04-2005 16:57:57
John,tractor will roll with it in gear with clutch NOT engaged,when I ingage clutch rear tires lock up..I can pull and get it roll while rolling I engage clutch rear tires lock up...is it possible clutch at that time sticks to flywheel????crank shaft will not turn...Thanks Dennis Fla.
John Saeli
02-05-2005 05:24:53
 Re: john saeli---clutch issue in reply to Dwhittemore, 02-04-2005 17:41:52
Sounds to me like the clutch is fine. What gears are you trying to turn the engine over in?
If you were in 3rd or 4th, sounds to me like the engine is seized or the Starter Bendix is jammed. Pulling the starter out will solve that.
DWhittemore
02-05-2005 07:06:13
 Re: john saeli---clutch issue in reply to John Saeli, 02-05-2005 05:24:53
John thanks,starter is off,think I will have to pull crank shaft and pound out pistons,didnt want to do that but gotta do whata I gotta do..Thanks again-Dennis Fla
