CASE Tractor Bearing ST395? What is it for?
Ignoramus76376
02-03-2005 21:25:46
Some case tractor bearings ST395 followed me home. I would like to know what they are for.
MATT MATERIAL STEEL BALL MATT MATERIAL STEEL INNER RING MATT MATERIAL STEEL OUTER RING MATT MATERIAL STEEL SHIELD STYL STYLE DESIGNATOR 10B LOADING GROOVE, NON-SEPARABLE ABMK OVERALL WIDTH 26.0 MILLIMETERS NOMINAL ABXV BORE DIAMETER 80.00 MILLIMETERS NOMINAL ADGA OVERALL OUTSIDE DIAMETER 140.00 MILLIMETERS NOMINAL CTFZ STANDARD TOLERANCE DESIGNATION ABEC NO.1 AGZD BORE SHAPE STRAIGHT AGYE SURFACE FINISH GROUND AGYK SHIELD QUANTITY 1 AGZC LOAD DIRECTION RADIAL AGZH INTERNAL FIT-UP DESIGNATION STANDARD CBBL FEATURES PROVIDED SNAP RING-GROOVE MOUNTING AND MOUNTING GROOVE
Roger H
02-06-2005 07:43:01
 Re: CASE Tractor Bearing ST395? What is it for? in reply to Ignoramus76376, 02-03-2005 21:25:46
Post this info over on the Farmall page, the 216 number sounds familiar, I wonder if they are rear axle bearings for M Farmalls, it sounds like these are good size bearings but I cant find a metric ruler in the house here to convert the damn metric to inches
george md
02-05-2005 20:11:36
If it was a bower / bca, the # would be 216,
seal on one side makes it a 216S , seal and
snap ring makes it a 216 SL.
george
caseman-d
02-05-2005 07:01:09
ST395 comes up as a trolley which has been discontinued and does not show what it's used on. There is another gentleman that posts on this site that has a book that may show where used. Maybe we will be lucky and he can tell us what it fits.
caseman-d
Roger H
02-06-2005 07:36:36
 Re: CASE Tractor Bearing ST395? What is it for? in reply to caseman-d, 02-05-2005 07:01:09
Tom, no such luck, none of any books I have here shows that number, I have no idea what they fit.....Roger
John Saeli
02-04-2005 04:48:59
All that info & you can't tell us where they go????
caseman-d
02-05-2005 06:31:06
 Re: CASE Tractor Bearing ST395? What is it for? in reply to John Saeli, 02-04-2005 04:48:59
John,
So in plain English you don't know???
caseman-d
John Saeli
02-06-2005 07:25:55
 Re: CASE Tractor Bearing ST395? What is it for? in reply to caseman-d, 02-05-2005 06:31:06
Hey caseman: You are correct!! I do not know. It is not listed in any books that I have.
