Case 310 (Gas) Piston Oil Ring
Jerry Kron
02-03-2005 14:08:44
Replacing rings on two of four cylinders of a gas 310. Piston oil ring packet provided by Case Parts (Part # G1063) has an oil ring that is wider than that being replaced and it is clear the two old thin rings that fit at top and bottom of oil ring groove are not to be re-used (the replacement oil ring will just fit the width of the groove comfortably). But not sure if the old expander spring is supposed to be re-used beneath this new oil ring to load it against the cylinder wall. Seems it might be a tight fit if the expander is to be reused with this new part number. Any one run into this problem? Jerry
JHH
02-04-2005 01:08:00
 Re: Case 310 (Gas) Piston Oil Ring in reply to Jerry Kron, 02-03-2005 14:08:44
Throw all the old parts away and use only the parts in the new set.
Jerry Kron
02-04-2005 14:48:17
 Re: Case 310 (Gas) Piston Oil Ring in reply to JHH, 02-04-2005 01:08:00
Thanks for the input JHH....it seems the new style oil ring is so hefty maybe it doesn't need an expander spring behind it to press on the cylinder wall... it just rides in there like the compression rings.
