Gov surplus VAC head gasket
other Will
02-03-2005 13:42:07
Have a Gov surplus head gasket for a VAC wrapped in some kind of heavy waxey paper. Same waxey stuff on the gasket. Should I remove the stuff off the gasket before useing it or will that help to seal the gasket? If I clean it off should I use any other kind of sealer?
JohnSaeli
02-03-2005 16:36:23
 Re: Gov surplus VAC head gasket in reply to other Will, 02-03-2005 13:42:07
Hey Will: That coating is Cosmoline, and it must be removed. I don't use any sealer. Some guys do. Don't know what they use. Be sure to Retorque the head when fully warm. To retorque, back each nut off 90 degrees, and come back up to torque. 1 at a time, in the same sequence that you originally torqued.
