Case 430 LCK clutch problem
Buck Moran
02-02-2005 16:33:40
My Case 430 LCK tractor has developed a loud growling noise when the clutch is released. The clutch seems to either be disengaged or engaged; there is very little transition. I suspect a bad throwout bearing or maybe the whole clutch is bad.
I have manuals, but any helpful ideas, suggestions, etc. Also where can I buy parts for this tractor, especially in NE Ohio?
Buck Moran
02-03-2005 20:56:58
 Re: Case 430 LCK clutch problem in reply to Buck Moran, 02-02-2005 16:33:40
Thanks for the info. I added them to my database for parts,. etc.
Wayne J
02-03-2005 11:11:18
Hay Buck try Lenox Equiment co rt. 46 south of Jefferson . thatin Aushtabula countie n/e Ohio ther phone # is 440 294 2900 tha are case ih parts dealer and they do have parts in stock Wayne J
Dennis/Ohio
02-03-2005 01:57:55
Hi Buck,
You may have a grease fitting on the throw-out bearing. Also don"t forget to have a little free travel before contact with the pressure plate. Without free travel the bearing would be spinning all the time. Best wishes, Dennis.....
Buck Moran
02-03-2005 05:38:38
 Re: Case 430 LCK clutch problem in reply to Dennis/Ohio, 02-03-2005 01:57:55
Thank you for the info. I"ll check and grease all the fittings on the tractor. I recently bought it and have never greased it yet. I also found out (in talking with the former owner of the tractor)that the manual clutch lever on the left side of the tractor may be partially engaged. I"ll check that today as well as greasing the fittings.
Regards,
Buck Moran
c hess
02-02-2005 17:45:34
forgot name an address of lancaster pa case dealer for parts --Binkley @hurst Bros 1-800-414-4705
Buck Moran
02-02-2005 18:04:06
 Re: Case 430 LCK clutch problem in reply to c hess, 02-02-2005 17:45:34
Thanks for the quick reply. I recorded Binkley & Hurst"s phone number, I"ll call them tomorrow. I have no specifics on the clutch problem yet, but I wanted to line up potential parts sources before tearing anything down on the tractor.
Any other ideas or advice will be greatly appreciated.
Thanks,
Buck Moran
c hess
02-02-2005 17:45:45
charles hess
02-02-2005 17:36:49
parts for case, old always case an very good!! will ship ups
