Does anyone have any suggestions on how I can get
Nicholaus Sowde
02-01-2005 14:56:55
Does anyone have any suggestions on how I can get my Vac running? I have fire at the points. I have gas at the carb. I put new spark plugs in. The gas is fresh. Thanks
James Herrman
02-01-2005 19:46:39
 Re: Does anyone have any suggestions on how I can in reply to Nicholaus Sowder, 02-01-2005 14:56:55
Just had the same problem with my F20. Had all of the above, plenty of gas running out of the carb, mag just went thru, in time, fresh gas, etc. My problem was a speck of dirt in the carb. I would suggest checking it. I had been thru my carb several times, but failed to install a fuel filter. Hope this might help. Also have a 31 Case CC and a 29 C. JIM in ILL.
Camboted
02-01-2005 15:11:50
Just look at simple stuff first:
Plug wires and Distributor cap? Working? Dry?
Do you have compression?
Timeing?
Fuel mix (How many turns on the fuel mix screw?)
Air cleaner? Is it clear or possibly full of ice? Dirt? Are you choking it to death?
Is choke working?
