Draft-O-Matic pump relief valve??
Steelmech
01-31-2005 20:52:46
On a 530 CK, deisel, -- I have hydraulics out for a new converter pump & would like to verify correct relief setting for the lift pump. The pump relief valve appears to have been tampered with, so need to verify how many turns in after seat contact or however it's set. The manual doesn't specify that I can find, except 1450 to 1550 psi, but, need to know before I put it back together.
Thanks for any help here...Regards
