What Tires?
Walt Banta
01-31-2005 19:47:37
Folks, Maybe someone out there can give me a hand determining what kind/size tires I need. I have an old Case DI(1945) that needs new tires. Presently, the front is fitted with 7:00X20's. The rear tires are mounted as "duals" but the tires are mismatched side to side. On one side, there are two 9:00X24 military nondirectional tires; on the other side, there are two highway type tires, and the only numbers I can see are 8X40, but they are mounted on 24 inch wheels. The front of the tractor seems to be too high in the front; however, the rear tires are either low, flat, or smaller on one side than the other,so appearances may be misleading. What type/size tires would be correct? Walt Banta
Don Livingston
02-01-2005 07:00:44
 Re: What Tires? in reply to Walt Banta, 01-31-2005 19:47:37
A Di could of had narrow or wide tires on the rear. I have seen them both ways. I have a matched pair of wide tires on rims. Don L.
Walter Banta
02-01-2005 18:44:58
 Re: What Tires? in reply to Don Livingston, 02-01-2005 07:00:44
Don Livingston, Thanks for your feedback on the tires. This DI has "dual" wheels(4 tires)mounted on the rear. They are 8X40 on one side and 9:00X24 military nondirectional on the other. An antique tractor tire dealer in Ohio tells me that they are the same size, but the 9:00X16's seem to be larger. Do you know where the "military tread tires" are available? Walt Banta
