Elmer, a question?
kyhayman
01-30-2005 18:59:08
By chance, would a 1210 transverse mounted power steering cylinder fit a 780 Case backhoe?
pete j
02-01-2005 14:10:20
 david brown info in reply to kyhayman, 01-30-2005 18:59:08
was wanting to know what years were david brown 770 select-o-matic made.also the horsepower at the drawbar,and pto.also the front and rear tire size.thanks
Elmer
01-31-2005 04:53:51
 Re: Elmer, a question? in reply to kyhayman, 01-30-2005 18:59:08
I have never seen a 780 Case hoe. Largest i ever came across is the 680. I would kind of doubt it would bolt up. But hey anything is possible. My brothers 1210 had a badly worn transverse cylinder. It was going to cost way too much to repair, so i cut the whole apparatus out and mounted a cylinder from a 1066 IH. If you have a good cylinder from a 1210 you could probably make it work!
Used to be James
01-30-2005 19:41:44
Kyhayman,
I'm not Elmer, and I can't answer your question. I have a question of my own,I know you are the expert, and I know you will be back here. I had some brome die last spring when I mowed it. I mowed late May or early June day after a 4 inch rain. So I sprayed roundup on the entire field to kill the weeds and fescue. One week later I no-tilled brome back. (Some of it I planted too deep, but not all of it.) I think this was late September/early Oct. Very little to none of the brome sprouted. I tilled some land of my neighbors and used the same no-till drill on him: his came up great. The land has been sopping wet most of the time since I planted it and still is today. I'm not sure why the brome died in the first place unless it could have been too wet? My question is what would you do at this point for the upcoming summer? I'm not going to hay it this year, but would like to graze goats on it. I know your first suggestion will be a soil test, and no I haven't had that done. I live just south of Kansas City.
Thanks for your time and your valued opinions.
James Martin
kyhayman
01-30-2005 20:03:24
 Re: Elmer, a question? in reply to Used to be James, 01-30-2005 19:41:44
Hi James,
Afraid I may disappoint you on this one. Brome (at least Smooth Brome) is difficult to establish but hard to kill. Unless this was a first year stand I have no idea what killed it the first time. As far as reemergence, I agree with you, too wet. Really waterlogged soils are tough on most of the grasses except reed canary grass. Prairie Brome is short lived and would have more problems in a stressful situation. Even the very best research agronomists have difficulty with brome and birdfoot trefoil. Sometimes you have good results, sometimes not. I've never been very successful establishing it drilled or no tilled. Decent success in a really good seed bed under ideal conditions. My experience has been, if you can get it and keep it 2 years, you may never get rid of it :-).
Sorry, wish I could have been more help.
Warmest regards,
David (and I never mentioned a soil test :-))
