Case 310 Stuck transmission shifter
John Davis
01-30-2005 06:46:59
I recently was using my case 310, and shifted from reverse to first gear.
Shift lever stuck in first and I can't get it out of gear. Tried removing the top cover to unstick it, and ran into a problem. (the shift rails hit the housing).
I have been told that the transmission has to be in neutral to remove the cover, "Catch 22" can't shift to neutral, and can't remove cover. Can anyone help? Thanks!
John Davis
05-17-2005 05:50:56
 Re: Case 310 Stuck transmission shifter in reply to John Davis, 01-30-2005 06:46:59
Sorry it took so long to get back. Finally pried off top of transmission. Bent one fork and one shifter rail.
All caused because the main holder spring broke and was jamming the shifting forks.
Got it all working finally.
Thanks for the help and comments.
Lincoln
01-30-2005 17:15:40
Have you tried jacking up a rear tire and moving it back and forth to see if will come un jammed? After you took the bolts out of the top cover can you get a long screwdriver inside to move the rail forward or move the forks?
John Davis
01-31-2005 06:08:16
 Re: Case 310 Stuck transmission shifter in reply to Lincoln, 01-30-2005 17:15:40
Actually drove it and tried to wiggle it free. No luck.
Haven't been able to get much of anything inside with enough leverage to move anything.
Will have to try jacking it up, hoping that that will free it up.
Thanks for the feedback.
JRT
01-30-2005 08:02:39
That can happen if the shifter fork get worn or bent. What usually happens is they will stick if reverse. I have had two Case tractors that would stick in reverse. To get the cap off, I would have to keep working it around and gently prying things around until it would finally come loose. It has to be in neutral and all forks spaced exactly right to get it back on.
John Davis
01-31-2005 06:03:07
 Re: Case 310 Stuck transmission shifter in reply to JRT, 01-30-2005 08:02:39
Not much luck in getting anything inside to move anything. Guess that I will just have to keep trying.
I guess that I was hoping for a simple solution.
Thanks again.
