No Steering or hydraulics David Brown 1410
jdabg
01-29-2005 18:35:41
Have no steering (all hydraulic nothing mechanical) and no hydraulic at the 3 point. I don't believe the systems are related. What type fluid do I use in each system? Is there a valve I'm missing. I just got the tractor home on a tow truck and it's real hard to move without steering.
Elmer
01-30-2005 13:52:47
 Re: No Steering or hydraulics David Brown 1410 in reply to jdabg, 01-29-2005 18:35:41
The power steering pump has its own reservoir on the right side of the engine. Make sure you have fluid in it. Otherwise put a gauge in the elbow at the top of the pump and check pump pressure. The three point hitch may not be working due to the combining valve in the wrong position. Check at the remote lever, you will see a little knob below the valve that slides in or out.
