830 LP brass fittings
C.H. (TX)
01-29-2005 17:59:29
I bought an 830 LP Comfort King that is missing one of the brass 1/4" compression fittings that connects the incoming gas tube to the Ensign regulator. The LP fittings on this tractor are not regular type compression fittings-- the compression nut is male threaded instead of female (see pictures). Does anyone know where to find these? Here is a link to pictures of another fitting on the same tractor...
piggybacked910b
02-06-2005 06:42:06
 Re: 830 LP brass fittings in reply to C.H. (TX), 01-29-2005 17:59:29
I ran into the same problem on my 910. Contact your local lp dealer and they should be able to help. Mine was able to find them in a catalog they had with lp fittings.
