problems with 188D
dwsc
01-29-2005 16:04:22
I have a 188 diesel in a 530 that is giving me a little problem, I overhauled the engine had the injectors rebuilt, and replaced the head, I was very careful when I took it apart to know which way and how thing were. I got the pump out of time, and when i first started it up I knew it,
I got it retimed, it still does not want to start unless you either it, even if it sets for over 5 minutes I have to either it again, it will smoke but not start, and the last time I started it It was acting like it was out of time again, smoking really bad but I can't understand how, could there something wrong with the pump. or could it be out of time again.
Tom (Ks)
01-31-2005 17:56:26
 Re: problems with 188D in reply to dwsc , 01-29-2005 16:04:22
I have seen a Rotodiesel pump that had the timing move around but not a Roosa Master. The engine still ran good, but smoked a lot. Could you have the valves set way too tight? Is the diesel fuel in good condition?
