bent push rods 51 Sc case
D.Whittemore
01-28-2005 14:52:18
My 51SC has stuck motor, removed valve pan ,saw that 5 of the push rods were bent,anyone tell me what could have caused it.I just got it. Knew the motor was stuck and working on it.Thanks Dennis
dctom
01-28-2005 15:43:38
 Re: bent push rods 51 Sc case in reply to D.Whittemore, 01-28-2005 14:52:18
valves were stuck and someone turned engine over and bent them they must have stuck before engine did tom
D.Whittemore
01-29-2005 03:03:11
 Re: bent push rods 51 Sc case in reply to dctom, 01-28-2005 15:43:38
dctom, thanks for your reply,can you tell me how unstick valves on 51 sc. motor is stuck also,soaking in pb blaster.thanks Dennis
dctom
01-29-2005 05:30:56
 Re: bent push rods 51 Sc case in reply to D.Whittemore, 01-29-2005 03:03:11
remove head, take to shop and have head rebuilt,
Walt Davies
01-30-2005 10:45:25
 Re: bent push rods 51 Sc case in reply to dctom, 01-29-2005 05:30:56
If you have a stuck engine and bent push rods I would not stop short of a complete take down of the engine better to be safe now than sorry latter on. I am presently taking a JD (UHG) apart that was frozen and have found all kinds of problems inside. the rods were frozen to the crank and it pulled the babbit when i turned it over the cylinders are sp bad that it needs to be bored and the pistens are scored beyound repair. Just an idea of what you might find inside your engine.
D.Whittemore
01-31-2005 15:45:05
 Re: bent push rods 51 Sc case in reply to Walt Davies, 01-30-2005 10:45:25
I pulled the head off today,three of the cyl.had mud about an inch thick,cyl walls look ok.two of the valves were open rest were stuck.push rods bent.if any one give me advice on the hand cluth,,,hand lever will go forward but real stiff,,is this right....Thanks ..Dennis
