Case C rear hubs
Jim Nicholson
01-28-2005 09:44:10
I am restoring a 1934 Case C and need to replace the rear rims. I have been unable to remove the rear hub from the axle and have tried red hot heat, a jack and chains etc with no success. Is there a trick? Thanks. Also any recommendations on what books are useful for restoring this specific tractor would be appreciated.
MS
01-28-2005 20:53:24
 Re: Case C rear hubs in reply to Jim Nicholson, 01-28-2005 09:44:10
Jim, I am assuming the axle is still on the tractor. I have used two port-a-power cylinders in the past to push the hub off. This may work better than a regular jack as most jacks are not made to work sideways. Try to keep even pressure on both sides and make sure you put the cylindres on a strong part of the hub, and it should push it off. This may be a little more difficult if the tractor has fenders on it but it should work.
Good Luck,
Mark
Dave Olson
01-28-2005 17:37:41
Hello Jim,
I have a Case Manual that has about half a dozen pages of drawings and descriptions on adjusting and removing the rear axle bearings.
The manual is titled Instructions for Operation and Car of the Case Model "C" Tractor. Eleventh Edition published 4-39.
If you have a fax machine, I could copy and send them to you, or just give me your address and I can mail copies of these pages to you.
Dave Olson - East-Central Illinois
Casenut
01-28-2005 15:39:26
Did you place the jack on the end of the axle shaft? Try to turn the nut on to the shaft so it is flush with end and hit it with a maul or try to hit the jack when there is pressure on it (this has never failed for me)
Ol Chief
01-28-2005 23:21:01
 Re: Case C rear hubs in reply to Casenut, 01-28-2005 15:39:26
If you have already cleaned all of the crud off of the axle Try packing dry ice on th shaft for an hour or so then attach your pulling device and get a good heavy strain.Then quickly heat the hub.I think a rose bud torch tip would work best to expand that hub quickly.Then apply hydraulic pressure asap.
