cleaning/servicing/adjusting injectors on 188D
BKahler
01-28-2005 03:25:03
One of the things I found when I tore the engine down to fix the knocking sound was the back 3 cylinders all had severe carbon build up with #4 being the worst. I think #4 might have been caused by the rear cam bearing not having been installed all the way and the lifter smacked into it. Its possible the lifter would hang on the bearing shell, don't know just a guess.
Anyway I'm thinking the carbon problem more likely was caused by faulty injectors and/or low compression. Possibly not creating the right spray pattern.
Since this was supposed to be a budget rebuild and I'm now at the point where I have to replace the crank (ouch!) due to the spun rod bearing I'm wondering if its possible for me to clean and adjust the injectors myself. I seem to remember reading some where that by hooking an injector up to a fuel pump and pumping (before installing the injector in the block) I could adjust it that way, or at least see if it wasn't working right. Is this true? If so is there anything I need to now, look for, etc before attempting this?
Thanks!
Brad
george md
01-28-2005 11:01:41
 Re: cleaning/servicing/adjusting injectors on 188D in reply to BKahler, 01-28-2005 03:25:03
Brad, 530 is old enough to have the large body injectors
and those are rebuildable as well as adjustable.
If you don't find someone local to do it ,throw them
in a box and I'll do them for you.
george
BKahler
01-28-2005 19:06:13
 Re: cleaning/servicing/adjusting injectors on 188D in reply to george md, 01-28-2005 11:01:41
George,
Thanks for the offer, I'll probably give you a call this weekend or early next week. Got a question or two anyway.
Thanks!
Brad
jdemaris
01-28-2005 06:13:30
Hooking them to the injector pump is, in no way, a thorough test. It IS a good simple test to ascertain if they are firing at all, if any orifices are plugged, but that's about it. When you test the injectors on an actual injector tester - i.e. a "pop" tester, it allows to check leak down rate before the check valves crack, set opening pressure, and a few other things. Running the injectors off the injector pump is too rapid and also does not provide you with the pressure setting on the injectors. We used to rebuild quite a few types of injectors, but usually NOT the little pencil injectors like the 188D or 207D Case uses. Some larger injectors allow either cleaning and relapping of the tips - or complete replacement of JUST the tips. With the little pencil injectors the tips are not replaceable. We used to take them apart, clean them up, and lap the valves a bit, and get some extra use out to them - but they will not last or perform as new. So, you say you're on a budget? You CAN do a quick test by hooking to the injector pump - but that's about it. And, you might extend the usuability of the injectors by resetting the crack pressures on them and cleaning and lapping - but unless you know what you're doing, it's not a good place to cut corners. The excess carbon could be from many things - worn pistons and sleeves, bad injectors, injector pump overfueled and/or the timing advance not working properly, etc. etc. The 188Ds are known to throw one particular rod but I can't recall which one. I have one in my shop with a rod hanging out the side of the block - and I've seen many other 580CKs with the blocks patched in the same spot.
