stuck hand clutch and motor
Dennis Whittemo
01-28-2005 02:38:30
Just got 1951 SC case,motor stuck working on that,but the hand clutch will not move,plus cant get anything to move into working order.This tractor has been sitting outside for many years .Dont know what an eagle hitch looks like.your help is needed.Thanks Dennis
Camboted
01-29-2005 16:08:21
 Re: stuck hand clutch and motor in reply to Dennis Whittemore, 01-28-2005 02:38:30
Hate to tell you this, but you might as well start taking it apart. Even if you get it unstuck, chances are about 90% you will still have a clutch problem. I'd check transmission bearings as well, sitting that long has probably done some harm.
C. Amick
01-28-2005 05:43:55
Remove the side covers on the clutch housing and soak the clutch good with some P.B Blaster. After it sits for 2 or 3 days, you may be able to reach inside with a pry bar to help you free it.
