Backhoe cylinder leakage
Skyhawk Greg
01-27-2005 07:22:47
Hello - I have a 1968 or 1969 Case 580CK backhoe that is used for light work, mostly in the back 40 type of thing. Because of this, it is only used sporadically throughout the year. It seems that if it sits for a while, that leaks occur in the rod seals. If the rod seals are made of leather(?), then perhaps they are simply drying up, and cycling the cylinders in and out would solve the problem. This seems to work sometimes. In other instances, the seals have been replaced by a local shop. Does anybody have experience or advice with this type of thing? Thank you. Greg
Roger (Mi)
01-31-2005 19:56:42
 Re: Backhoe cylinder leakage in reply to Skyhawk Greg, 01-27-2005 07:22:47
No leather seals are used in your backhoe. Martin Fluid and Power in St. Joseph, Michigan sells complete cylinder kits at reasonable prices. That's the cure for your problem.
Roger (Mi)
01-31-2005 19:56:39
Skyhawk Greg
02-01-2005 07:56:45
 Re: Backhoe cylinder leakage in reply to Roger (Mi), 01-31-2005 19:56:39
Thank you Roger.
