case 580 D
Darell K
01-26-2005 15:56:31
Have a power steering problem and looking for suggestions. The unit steers fine with a light load in front bucket but has no Power steering at all when loaded. Steering wheel just turns but not the front steer tires.
just 580's
01-26-2005 21:20:42
 Re: case 580 D in reply to Darell K, 01-26-2005 15:56:31
Oil bypassing the power steering cylinder pistons. Re-seal the cylinders.
DKase
01-26-2005 18:35:28
First thing you need to do is check the pressure of the steering circuit. If OK does it have a hydraulic cylinder that steers the front end? If so I would try to plumb in a normal remote cylinder in place of the steering cyl. Set it upright under the tractor and turn the steering wheel. If it lifts the tractor you know that the piston seals are out of the steering cylinder. If no pressure to the cyl. you know the control valve that the steering wheel hooks to is bad. LOL DK PS For those that don't know me I am Darrel K
Darellk
01-27-2005 13:24:12
 Re: case 580 D in reply to DKase, 01-26-2005 18:35:28
Thanks for the info. Had a hunch this was the answer.
