George & jdemaris, Thanks for the replies. I dropped the block off at the machine shop. The liners measure out ok for doing a hone only. The insides of the engine with the exception of a couple of items I'll bring next looked pretty good. It appears there was a rebuild done on the engine not all that long before I got it. I think the reason it spun a rod bearing (#1) was because the rear cam bearing was only halfway installed, effectively blocking oil flow through that point. That caused the lifter to crush part of the bearing itself. It didn't look like the cam bearing spun, just not installed right. The pistons look fairly new and are in good shape overall. I might look into knurling to see if they can do it. It turns out the NAPA store close to me has an excellent machine shop and reputation. Thats the good news, the bad news is the #1 rod journal is at least .040" smaller in diameter than any of the others. So this crank is ruined unless something like the metal spray that George does or welding up the journal would work. I'm now looking for advice on how to salvage the crank or barring that find the best (meaning cheapest) source I can for a different crank. This is a 188 diesel with I believe the smaller diameter liners if that makes any difference. Any and all advice appreciated. Other than selling the tractor! You can see pictures of the rebuild on our website. Just look for the 63 case backhoe link on the left side. Thanks Brad PS, looking at our "projects" will give you an idea as to why this has to be a budget rebuild!
