Build card
jncaseman
01-25-2005 09:18:25
DCTom, Sure would appreciate any info on RC 4230189. Dad bought this tractor in 1940. It was a demostrator. It is styled,flambeau, and has the fourth gear but the number four is painted on the housing. We think maybe it was sent back and made into a styled tractor but we have never been able to find any evidence of gray paint on it. He paid $900.00 for the tractor,$600.00 for a model F combine, and $60.00 for a steel wheel wagon. We still have tractor and wagon but combine got sent to scrap yard.Thanks!
CK RICHARD
01-25-2005 15:25:00
 Re: Build card in reply to jncaseman, 01-25-2005 09:18:25
Does any one out there have a late RC that has the 4th gear marked on the housing?just asking my dads has 4th but is not marked.
Gene Dotson
01-25-2005 16:12:46
 Re: Build card in reply to CK RICHARD, 01-25-2005 15:25:00
It is my understanding, and I could have been wrong, but all the R and RC tractors were built with 4 speed transmissions. Tractors shipped with steel wheels had 4th gear blocked out by a plate in the shifter. When the tractor was put on rubber tires, the shifter was removed and the blocking plate was removed. I welcome any correction if this is wrong... Gene
mike o.
01-26-2005 09:46:54
 Re: Build card in reply to Gene Dotson, 01-25-2005 16:12:46
In reference to your post, i have a 36" rc on steel. i"m in the process of releasing the motor that is froze..... but i have moved the shifter in any and all ways to try and find that elusive 4th gear in mine and can"t find it. so, i would venture to say that you are correct in your statement. i"m new to the mechanics of these ol" girls. if that is the case where you would have to remove the plate to have that 4th gear, i"m taking an educated guess that you would have to crack the tractor to do so?
JR(CASE38MAN)
01-26-2005 12:51:02
 Re: Build card in reply to mike o., 01-26-2005 09:46:54
4TH GEAR WAS NOT ADDED TILL LATE 1938..FROM THE BOOK "CASE GP TRACTORS"BY ROBERT PRIPPS & ANDREW MORLAND..By 1939, the R and RC were each given a cast iron "sunburst" grill and the new Flambeau Red paint..They also got a four-speed transmission and a starter and lights option..The RC got a Motor-Lift.. NO R OR RC CAME WITH 4TH GEAR MARKED ON THE HOUSING. THERE WAS NO LOCK OUT BECAUSE THERE WAS NO GEAR THERE... JR
