Vac grounding?
Dave
09-07-1999 17:57:56
I have a '51 VAC and would like to know if it originally was positive or negative ground. I bought it last year with no battery. I put a 6 volt in and made negative ground. It charges okay. I'm wondering if this is the original generator.
ltf in nc
09-12-1999 19:14:45
 Re: Vac grounding? in reply to Dave, 09-07-1999 17:57:56
You already have your question answered but I suggest you leave the tractor Neg. ground. It has to do with the firing of the sparkplug when the engine is hot. The center electrode has a high negative potential from the coil and when hot the current flows better due to the electron flow. If you are interested in this, research the Kettering ingnition system as designed by Charles F Kettering
Jerrie Lott
09-07-1999 18:40:30
I am almost positive that new they were Positive ground, but a generator can be made to charge either way all it has to be is polarized. I can't remeber the reason for the ground being that way. I think the older Ford cars and trucks were that way too, Maybe someone else remembers why some things were built neg ground and some pos ground.
Marty
09-09-1999 18:01:02
 Re: Re: Vac grounding? in reply to Jerrie Lott, 09-07-1999 18:40:30
My 51 is positive ground. How many lbs. oil pressure does your's run? Mine is a little weak at 10 lbs. warm.
