VAC starter going bad
Tractor Dave MI
01-24-2005 19:02:01
I need some advice guys.... The starter on my VAC (6 volt system)has been wining & sticking the last few weeks. The tractor sits indoors. If it won"t catch I can release the starter button and try again and most times it will catch. Lately though the starter has been locking up and I have to crank start it. Anything I can do or should I take it into the auto parts to be rebuild. How much can I expect to pay to have it rebuild?
CLIFF
01-26-2005 04:31:39
 Re: VAC starter going bad in reply to Tractor Dave MI, 01-24-2005 19:02:01
Make shure the battery is charged up all the way, wen my vac with 12V sits a long time in winter it will do the same thing.
wayne j
01-25-2005 13:14:16
take the starter to a starter gen. alt. shop it will only get more expensive starter rebild is cheaper then starter rebild and ring gear replace Wayne J
Paul f
01-25-2005 06:43:24
as mj said time to take it in..mine had a bent shaft.
While it is off check the ring gear. Will probably find oneo or tw small areas of wear...engines like to stop at the same point most the time
mj
01-24-2005 20:58:37
The last one I had rebuilt by a shop cost me $60. If you wait too long and ruin the armature it will be more.....a LOT more.
