Stuck motor
Rockcricker
01-24-2005 16:56:52
Was pulling my 48 case sc to ture the motor over and was working ok and then just stopped. Split tractor and checked clutch and looked ok. What should I do next.
Rockcricker
01-25-2005 17:41:15
 Re: Stuck motor in reply to Rockcricker, 01-24-2005 16:56:52
Well I pulled the head and it turned over fine. Didn't see anything. The head looks fine to. Who know's.
Gene Dotson
01-25-2005 16:45:06
I had 2 unusual occurrences like this. The first one on my VC, the engine turned over for a while and then locked up tight. I pulled the head and carbon had broken loose and 2 pieces stacked together and wedged against the head. On my VAIW I bought, after I got it broken loose, would only turn about 300 degrees in either direction. When I pulled the head off this one, I found a hickory nut on top of the piston. How do those critters get a nut through that little valve opening??? Gene
C. Amick
01-26-2005 05:44:36
 Re: Stuck motor in reply to Gene Dotson, 01-25-2005 16:45:06
I was helping my neighbor work on an old Moline that was full of hickory nuts as well.
C. Amick
01-25-2005 08:51:38
Have you tried turning the motor by hand? It won't move in either direction? Could something have gotten into the cylinder through the exhaust? How cold was it, could there have been ice inside the engine when you were trying to start it? I broke the teeth off an oil pump due to ice in the engine.
Glenn F.
01-24-2005 20:04:46
Is your starter locked up? My '54 SC locked up too. It had a bad ring gear and starter drive. Pulled the starter out and engine was free. Glenn
Rockcricker
01-24-2005 20:19:58
 Re: Stuck motor in reply to Glenn F., 01-24-2005 20:04:46
I have pulled the clutch and flywheel. So It couldn't be that right?
Camboted
01-24-2005 21:59:58
 Re: Stuck motor in reply to Rockcricker, 01-24-2005 20:19:58
If it is not a jamed starter, can you turn the motor over with it discinnected from the transmission, with clutch pulled?? If so, then you might as well take the valve cover off, check for stuck valves, then, check the pan through the side covers,if neccessary head off and go from there, to the timeing cover. You'll find your problem somewhere. If the problem is in the transmission, chances are you have a brokrn or badlt worn chain.
