LA PULLER
The eagle
01-24-2005 15:54:35
I would like to know how well a LA will run with 4 7/8 flats with a Propane head. I would also like to know if it is worth the effort to put a different cam in it.
laipuller
01-24-2005 21:24:18
 Re: LA PULLER in reply to The eagle, 01-24-2005 15:54:35
i firmly believe that 2000 rpm is stretching it, about 1500 is all i ever try to run mine at, but makes its best power at 1200 neighborhood. as far as bore, use your imagination, and it can just about be done...good luck.
mike's600
01-24-2005 17:53:51
What kind of RPM are you going to run?
Eagle
01-24-2005 18:20:23
 Re: LA PULLER in reply to mike's600, 01-24-2005 17:53:51
Plan on around 2000 or so. Just dont know how much hp it will make. I have heard the stories of 100 to 120hp. That just seems out of reason but might not be. I know a guy who has one with 4 3/4 flats with a shaved and ported high comp gas head. He only is getting around 80 or so out of it. So thats why i was wondering if anyone had put one set up this way. thanks
Paul D
01-26-2005 20:53:48
 Re: LA PULLER in reply to Eagle, 01-24-2005 18:20:23
I after repainting my dads old LA at my tech school for AG mechanics we put the old girl on the dyno and made 105hp. This tractor is 100% stock, the dyno is right on the money in its calibration also. Don't under estimate what those tractors will do on the dyno in stock form.
Alan.T. Lewis - New Zeala
01-24-2005 19:47:27
hello Eagle (Old Abe)
I note with interest that you intend putting large pistons into you "LA", for pulling, well she sure would pull alright, BUT before you start running that big unbalanced engine, you MUST have it perfectly balanced otherwise it would most likely self destruct in a big way, as they are not originally balanced at all as they only run at 1,100 R.P.M - for what it's worth.
Regards - Alan T. Lewis NEW ZEALAND
Old L Case Puller
01-25-2005 07:41:44
 Re: LA PULLER in reply to Alan.T. Lewis - New Zeala, 01-24-2005 19:47:27
Used to pull a stock bore and stroke 1936 L Case many years ago.Turned it 1800 rpms lots of times with no problems.Maybe I just got lucky.
Mike's600
01-26-2005 18:34:40
 Re: LA PULLER in reply to Old L Case Puller, 01-25-2005 07:41:44
Hey, 80 hp sounds closer to being right than 120hp. Post a message on Old powerpride's web site, ask for Casepower. I'am sure he has built and LA or knows someone who has, and they should be able to help you with your set up.
Good Luck. My 600 Case dsl takes good care of those JD's G to 830 !!
laipuller45
01-26-2005 22:00:26
 Re: LA PULLER in reply to Mike's600, 01-26-2005 18:34:40
you can get 200+ out of an la
