Dual Rear Wheels and Weights
Walter Banta
01-24-2005 14:37:29
Gentlemen, I have another dilemma, and I am hoping you can help. I must transport a Case DI that is fitted with dual rear wheels and weights. The "Bobcat-type trailer" that I have found is only 6 feet wide, and the tractor is 7 feet wide outside the rear wheels. There is also insufficient room behind the fenders for the dual wheels and for the ramps to fold up. Question/Solution: How difficult is it to remove the outside dual wheel and weight from each side so that it will fit the trailer? I have heard that the wheel weights are 280 lbs. each. 1. How does one "manipulate" this load? 2. Can the "outside" wheel be removed without disturbing the attachment of the "inside wheel"? Obviously, I am "wet behind the ears" regarding tractor mechanics and maintenance. Walt Banta
Goldie
01-24-2005 14:51:51
 Re: Dual Rear Wheels and Weights in reply to Walter Banta, 01-24-2005 14:37:29
I have a LA that is wider than the fender wells of my trailer so I block up one side so the wheel clears the fender. People look at me funny, but I have not had problem yet.
