VAC case
Eldo Case
01-24-2005 07:56:54
You should have see a little vac hold its own at carthage NATPA pull. You would have been proud how it held up to the so called c farmalls. 2ed by less than 12 inches is not bad when you only have 14.9x28 & he has 16.9x34 tires.
silverking
01-24-2005 14:50:18
 Re: VAC case in reply to Eldo Case, 01-24-2005 07:56:54
SSSHHHHH , Case is the best kept secret out there, As DCTom says stock they have a lot of potential, if there were as many Cases as other makes on the strip they would place well,properly tuned DC's especially in stock classesdo well.
Pawn
01-24-2005 15:35:51
 Re: VAC case in reply to silverking, 01-24-2005 14:50:18
I know the owners of this tractor quite well and it has been done the poor boy way so that just shows that speed limit is the great equalizer. Plus the tractor is no slouch.
Bean Burrito
01-25-2005 21:56:42
 Re: VAC case in reply to Pawn, 01-24-2005 15:35:51
I should say it is no slouch...Heck I heard about it all the way down here in this bordertown. I think they should bump the speed up to 5 mph and let them see what the little case can do with 18.4 x 38's....ha ha ha
