Hey mEL?
Larry W.
01-23-2005 12:02:54
Hey Mel, how many rpms did you turn it? Ever have any trouble with the lower end, or the rods?
mEl
01-23-2005 12:52:10
 Re: Hey mEL? in reply to Larry W., 01-23-2005 12:02:54
Larry, the pan has never been off the engine, any work done was through the side pans. never loosened a rod although one was replaced for chunking out on the brg surface, M&W pistons broke at the lower oil ring groove allowing it to rock badly so we took them out and put flattop ones in. Until recent years the tractor mowed setaside land till I bought Dad a 830 lo profile to mow with. We had orchard sprockets in the rear with the 18.4-38 rubber, made for some fantastic speeds, we now have a different tractor with the same gear setup pulling antique which will pull over 11 mph on a sled monitor in a non rpm controlled class. Antique ,nonturbo with the same gear setup, probably 3000-3500 on the turbo setup, we had some fantastic runs at 4500 AND 5000 LBS but restrained ourselves from pulling heavier,The driver in the pics is my brother who worked with me building and maintaining it. In its day it was tough to beat. mEl
Larry W.
01-23-2005 19:17:18
 Re: Hey mEL? in reply to mEl, 01-23-2005 12:52:10
With the orchard sprockets, what gear would you run her in? I am amazed the rods and such took the abuse like that, wow!
mEl
01-23-2005 19:21:23
 Re: Hey mEL? in reply to Larry W., 01-23-2005 19:17:18
3rd with lots of reserve power, not bad for only a 4 spped. mEl
Larry W.
01-23-2005 20:21:02
 Re: Hey mEL? in reply to mEl, 01-23-2005 19:21:23
How bout the clutch??
mEl
01-24-2005 03:56:38
 Re: clutch in reply to Larry W., 01-23-2005 20:21:02
Larry, Updated the 39 to the later over center clutch, with enough tight it was adequate for all we did. Our recent puller was more of a problem and we changed that to dry and put a Competetion Chevy PP in that, quite more of a project. Plate between engine and bell with a seal in it a wear sleeve on the crank and machining everything so it would work, had to take some off the front side of the flywheel to make up for the plate thickness. The 39 never refused to lock up and you could use it like a slipper if needed!! and that disc is still in it. BTW, we still are running the NTPA required steel flywheel in that one. mEl
