930 Head Info
Bill Truscott
01-22-2005 16:34:47
Can anyone tell me the casting numbers for the LP heads vs. the gas heads on a 1962 930 6-speed wheatland with a 377 cid engine? Thanks for anything. BT
Roger H
01-22-2005 17:50:12
 Re: 930 Head Info in reply to Bill Truscott, 01-22-2005 16:34:47
Bill do you need casting or part numbers? There was no gasoline 930's until 1965. I can go out to the sheds to look at my '63 LP & '65 gas 930's if you need me to. I will look to see if the LP heads were the same on the 730 & 930's, they should be since the 7 & 930's used the same sleeves & pistons, basically the same engine other than 4 or 6 cylinders.
Roger H
01-22-2005 18:12:30
 Re: 930 Head Info in reply to Roger H, 01-22-2005 17:50:12
Bill, I looked in the parts books & I guess the part & casting number is the same in this situation, I'll have to go look to see what heads are on the 930 gas.
BT
01-23-2005 06:01:50
 Re: 930 Head Info in reply to Roger H, 01-22-2005 18:12:30
I have the opportunity to buy some heads for a LP 377 and just wanted to know if they were for sure LP heads and not the gas ones. Thanks, BT
Roger H
01-23-2005 08:02:43
 Re: 930 Head Info in reply to BT, 01-23-2005 06:01:50
The LP heads are A21356, gas are A21357
BT
01-24-2005 16:46:19
 Re: 930 Head Info in reply to Roger H, 01-23-2005 08:02:43
Thanks very much, BT
