trans swap
garyhb212
01-22-2005 12:58:09
i need help on trans for a 83 chevy truck so i can trailer my case 830 to shows. what will it take to change from a 350 to
a 400
garyhb212
01-23-2005 10:43:49
 Re: trans swap in reply to garyhb212, 01-22-2005 12:58:09
thanks for the input ,maybe i should rethink
this idea.
Oklahomatractorrebuilder
01-22-2005 21:21:23
It is basically a bolt in change except for the following items: drive shaft will have to be cut and either lengthened or shortened depennding which tail shaft it has, front yoke has to be changed, electric kick down switch has to be installed on throtle pedal for 'passing gear' to work, change your speedometer gears to the same number of teeth as your old trannie, and be ready to move your rear trannie mount and crossmember to fit. I changed our 85 suburban from a 700R to a 400 and these were the only changes I found. We also changed the rear axle gears from the 3.43 gears that are used with the overdrive trannie to a set of 3.07 ratio for better economy. Tim
Dooley
01-22-2005 20:31:36
I agree with KJM! You should at least have a 20 series with the Corporate 14 bolt full floating rear axle, preferrably with the heavy duty JB8 brake option.
kjm
01-22-2005 18:40:11
As a guy that worked for a Case dealer when the 830 were new, there is no way I would pull a 830 with a 1/2 ton truck. You do not have enough brakes to even begin to stop that load.
Dooley
01-22-2005 14:29:39
If the truck is original, it should have a 700R4 transmission. Is it 10/20/30 seies? Is it 4wd? Does it have overdrive? The 400T has a larger tailshaft diameter than the 350. It is also longer which means a shorter driveshaft is necessary.
garyhb212
01-22-2005 15:00:25
 Re: trans swap in reply to Dooley, 01-22-2005 14:29:39
it's a c10. it had a 305 2 wheel drive.
trans is a 350 whith lock up converter.
trans is 30 in. long.i have a 350 engine to put back in it
Dooley
01-22-2005 14:28:45
If the truck is original, it should have a 700R4 transmission. Is it 4wd? Does it have overdrive? The 400T has a larger tailshaft diameter than the 350. It is also longer which means a shorter driveshaft is necessary.
Dooley
01-22-2005 14:27:30
If the truck is original, it should have a 700R4 transmission. Does it have overdrive? The 400T has a larger tailshaft diameter than the 350. It is also longer which means a shorter driveshaft is necessary.
dctom
01-22-2005 13:12:54
tradeit off for a dodge turbo diesel lol tom
garyhb212
01-22-2005 13:33:07
 Re: trans swap in reply to dctom, 01-22-2005 13:12:54
i could buy a lot of tractor for that kind of money.
