CASE L
I.D. Rather
01-21-2005 19:32:41
When I took the all-fuel manifold off my Model L, it had what looks like two reducer tubes inserted into the intake ports of the head. These inserts reduce the ports to approx. 1" inside diameter. I found a replacement gasoline manifold off a Model LA that did not have the inserts. Can somebody tell me what these inserts are for? Do I need to use them on my L with the LA manifold? Thanks guys.
Don L.
01-21-2005 19:46:37
 Re: CASE L in reply to I.D. Rather, 01-21-2005 19:32:41
They are inlet venturi[s],for the low cost fuel manifold, not used with a straight gas manifold. The LA gas manifold used furrules in both intake and exhaust ports. Have the replacement manifold planed flat, and don't tighten the hold downs to death.
Don L.
