up and down a hill
RBF
01-21-2005 08:54:04
third party image
The 48 VAC I own has no brakes, is it possible to just use the transmission and engine to slow it down or keep it at a steady speed? I put a dirt road in this past summer to the lower part of our property and need to pull a truck out that somehow got stuck. I understand about going sideways but what about straight up or down a small hill?
PatMN
01-22-2005 18:26:30
 Re: up and down a hill in reply to RBF, 01-21-2005 08:54:04
No brakes going down hill and not pulling anything is not really a problem. Is there a place at or near the bottom that allows you to turn around or change the angle so you can stop? Now thats the question. Other than that pick a gear that will allow you to slow the VAC down when you near the bottom and then use the throttle to slow down. When going uphill it has to be a non stop operation. Again pick a gear that will pull the load non stop to the top of the hill and make sure the driver of the truck understands.
On our farm the hills are about twice the drop of yours and we do the above quite frequently. Now like a fellow poster said "The tractor never comes out of gear and never clutch" unless you really like to test you adrenalin levels.
Have fun.
Pat
rbf
01-23-2005 18:36:20
 Re: up and down a hill in reply to PatMN, 01-22-2005 18:26:30
Pat,
Yes, there is a place to turn around at the bottom and to stop. Just waiting for it to warm up a bit and to dry out. Thanks for the advice not to stop going up too!
case poor in pa
01-22-2005 03:39:53
well young feller first off what was ya doing way down that hill ?? was ya sparking or a spooning?? you could do like my uncle hank.he was going down east hill one time when he was a mite foolisher in his young days.its bout 3 miles long and 11 percent grade .him being speed champ of covington kicks th ole case outta gear and got some speed up thn relized he was past safe braking speed. they figger he was goin 50 miles an hour when he crossed the main hiway.he was lucky that time
Don Livingston
01-21-2005 09:54:47
 Re: up and down a hillbilly highway in reply to RBF, 01-21-2005 08:54:04
It is hard to tell the grade of the hill from the pic. Without brakes looks to be the hillbilly highway. Take time to take the brakes off , clean and inspect and adjust. The older disk style brakes will rust to the splined brake pinion. They have to move a bit back and forth. Not a big deal to do. Get another truck to pull the P/U out, a vac is too light, unless you really have alot of ballest and a nylon strap .
Don L.
RBF
01-21-2005 17:53:41
 Re: up and down a hillbilly highway in reply to Don Livingston, 01-21-2005 09:54:47
Don, Thanks... steep? yes a bit.
