What kind of a Case?
Ultradog MN
01-20-2005 14:38:21
Howdy Folks,
I"m sneaking over here from the Ford boards.
Got a couple of questions about a Case that I see just sitting on my way to work.
The paint is pretty faded so I can"t really tell what it is. I can see 4?? on the side of the hood
and --omatic on the other side. Looks like about a 30 - 40 hp tractor. Has 3 pt hitch, is gas, wide front.
There are twin headlights set Into the front nosepiece above the radiator. I was looking at the tractor photos here and found several 400s but they only had a single headlight.
I stopped in about a week ago and talked to the wife who gave me their phone #. Talked to the husband a couple days later but he knew little about it - belongs to his FIL - ran good when he parked it there a couple of years ago but wouldn"t fire last summer.
Looked faded but had servicable tires all around and wasn"t beat up or welded on or real greasy.
I don"t know if I am giving enough info to go on here But I"d appreciate any clues you might give
as to year, reliability and value. Thanks
Jerry
gary case
01-22-2005 07:05:08
 Re: What kind of a Case? in reply to Ultradog MN, 01-20-2005 14:38:21
jerry i have a 400b(411b)caseomatic square nose lights (two) in front clip.1959 it will have the radiator cap on the outside of the sheet metal the 58 has the snap in cap like the gas and battery covers. id tag should be on left side of dash below the dash. also 59 started after ser# 6120001. good condition 2500.00 to about 5000.00. this is what i found out on yd from c. amickand camboded that spelling is wrong. but they seem to know this stuff formm alot of knowledge.make sure you check out the caseomatic there $.if will start, let warm up, rev up and back down to a low idol and shift. this tractor woprks better with the foot throttle, rather than the lever. esp. for shifting put in gear and it should just sit there and then you throttle with foot pedal, witch is another way to tell the year kinda 59 has the flat foot pedal the 58 has the round bar foot pedal. well i hope this helps. i think i must have drank to much coffee this morning (sure have alot to say). gary case
Ultradog MN
01-21-2005 13:12:29
Thank you.
It looks like it's a 400B
Any idea what it's worth?
Jerry
Gene Dotson
01-20-2005 15:15:53
Try your search for 400B or 430 and see if you come up with a closer picture. Could be either one with Case-O-Matic drive. Is it a standard or adjustable row crop crop tractor? The 400B and 430 were about 32 horsepower tractors... Gene
dctom
01-20-2005 15:09:36
sounds like a 400-B case-o-matic, darn nice little tractor, about 40 hp and very handy after you learn how to run the com
