Case 930 to Case 1030 PTO Will the pieces fit
Brian White
01-20-2005 06:47:15
I am in question looking for someone with more knowlege than me. I need to know if the PTO out of a 930 comfort king 8 speed will fit a 1030 comfort king 8 speed. I know that case reused a lot of parts on different modeles but I don't know about the 1030. Also I had a guy tell me that case put most everything inside of the trany housing excpt for the shaft and different cover but he wasn't sure, Any help is appreciated. Thankyou in advance.
Brian in Kansas
Jeff From WI
01-20-2005 16:26:06
 Re: Case 930 to Case 1030 PTO Will the pieces fit in reply to Brian White, 01-20-2005 06:47:15
Hi Brian, You have some 930 or 1030 parts for sale? Or a 930 parts tractor? Thanks Jeff from WI.
Brian White
01-20-2005 20:08:19
 Re: Case 930 to Case 1030 PTO Will the pieces fit in reply to Jeff From WI, 01-20-2005 16:26:06
I have a gentalman that I am trying to help get a pto into his 1030 8 speed, and the one I have is from a 930 8 speed. I have a 930 Six speed pto and some other parts I have aquired that are for sale If you are needing anything, I have A few odds and ends (injector pump, hydraulic pump, I just bought some heads but I have to go get them off of the parts tractor that they are still on). If you need something email me at [email protected]
Sincerely
Brian White
Don L.
01-20-2005 06:51:19
Yes they will intrchange. Lots of people like to replace the 1000 in the 1030 to the 930 540 pto.
You don't need the whole pto , just part of it to convert.
Don L.
Brian White
01-20-2005 10:29:36
 Re: Case 930 to Case 1030 PTO Will the pieces fit in reply to Don L., 01-20-2005 06:51:19
So does the 1030 without the pto still have the clutch and the gears on the inside??
Thanks
Don Livingston
01-20-2005 16:15:45
 Re: Case 930 to Case 1030 PTO Will the pieces fit in reply to Brian White, 01-20-2005 10:29:36
Very very doubtfull. NO is more appropriate.
Don L.
Brian White
01-20-2005 20:02:59
 Re: Case 930 to Case 1030 PTO Will the pieces fit in reply to Don Livingston, 01-20-2005 16:15:45
Ok But now is the Other Big Question, Will the Clutch and gears from the 930 8 speed fit the 1030 8 speed???
I am greatfull for your time and help.
Sincerely
Brian White
Don L.
01-21-2005 04:45:40
 Re: Case 930 to Case 1030 PTO Will the pieces fit in reply to Brian White, 01-20-2005 20:02:59
If they are both 8 speeds yes. Don L.
Brian White
01-21-2005 05:45:02
 Re: Case 930 to Case 1030 PTO Will the pieces fit in reply to Don L., 01-21-2005 04:45:40
Thanks a Bunch.
