Converting ac to dc ???starter replacement
S�ren DY
01-18-2005 13:20:12
I'm in the proces of replacing the ac dynamo on my DB 1200 to a dc generator from my db 990.
Reason : bourght the 1200 with a totaly melt down wiring harness.
Q : converting to negative ground will it be nessesary to replace the starter or does it have some kind of logic ensuring that the starter dosnt turn the engine the wrong way round.
Best regards
S�ren from Denmark
Jerry W
01-18-2005 15:57:16
 Re: Converting ac to dc ???starter replacement in reply to S�ren DY, 01-18-2005 13:20:12
Just make sure that the regulator you plan on using is negative ground.
Jerry
Jerry W
01-18-2005 15:55:43
I know of no common starters that are polarity sensitive. It should work and spin the right way regardless of ground orientation.
Jerry
S�ren
01-18-2005 19:40:07
 Re: Converting ac to dc ???starter replacement in reply to Jerry W, 01-18-2005 15:55:43
Thanks a bundle
S�ren
