ji case desert sun paint
gary case
01-18-2005 07:53:51
where does a person find this color its not in tsc or places like that they always have flambeu red..... ..... .... not that i don't like it. gary case thanx desert sun
Lincoln
01-18-2005 15:06:10
 Re: ji case desert sun paint in reply to gary case, 01-18-2005 07:53:51
The PPG/Ditzler 81357 is an old number, but they can color matach one to it. I had to call the PPG tech line to get the paint code to give to the auto store. I thought the paint was hard to get good coverage with out runs. The results look nice though. Good luck.
gary case
01-18-2005 12:51:26
 ser#s gone case in reply to gary case, 01-18-2005 07:53:51
how would you determine what ser# tractor i have? engine#152 r18139 thats the old engine ser# it has a different shortblock in it now i have the case 300b-400b series tractors begining with ser# 6095009 parts catalog #r.i. a377 looked up ser#'s and the 411b was close but no cigar. want to register her. i don't quite know if i can. gary case thanx for the info in advance.
Joe (Wa)
01-19-2005 10:17:04
 Re: ser#s gone case in reply to gary case, 01-18-2005 12:51:26
The 411B was built in 1958 & 1959. There are some minor differences between the 58 & 59. Check the grill cap in you parts book page 80-81. Also for other serial nr specific parts. That's is probably as close as you can get.
Joe
gary case
01-19-2005 13:29:45
 Re: ser#s gone case in reply to Joe (Wa), 01-19-2005 10:17:04
joe thans. i'm looking at the front clip and your right. i've got the one with the radiator cap hole ser# g14400 or g14382. so that means mine is a 19.. gary case
Joe (Wa)
01-19-2005 17:53:00
 Re: ser#s gone case in reply to gary case, 01-19-2005 13:29:45
After serial #6120001 is 1959. Look through the parts manual, there are other differences 58/59.
gary case
01-20-2005 07:30:35
 Re: ser#s gone case in reply to Joe (Wa), 01-19-2005 17:53:00
thanks joe i'll keep looking.gary case
C. Amick
01-18-2005 13:37:25
According to the serial number reference on this web site, the 1958 models started with serial number 6095001 and the 1959 models started with serial number 6120001. The older Cases had the serial number stamped on the outside edge of the engine flange where it bolts to the bell housing on the left side of the tractor, but I think Case had stopped doing that by the time your tractor was made.
gary case
01-19-2005 13:42:32
 Re: ser#s gone case in reply to C. Amick, 01-18-2005 13:37:25
thanks c. amick in my parts catalog it has a picture of a ser# on the side on a tag 411b h ser# like you said is 6120001, but thats probalyjust a picture.this was my dads book
C. Amick
01-18-2005 09:49:33
Here are the numbers that I've seen:
Desert Sunset: Dupont 75194D, PPG/Ditzler 81357, Case/IH B17651 Qt. or B17652 Gal. I think the Dupont and PPG paints are both acryllic. The Case/IH paint is synthetic enamel.
gary case
01-18-2005 11:36:06
 Re: ji case desert sun paint in reply to C. Amick, 01-18-2005 09:49:33
thank you do you go to a aoto shop or a store? gary
C. Amick
01-18-2005 12:12:25
 Re: ji case desert sun paint in reply to gary case, 01-18-2005 11:36:06
I pulled the information for you by doing a search of the Discussion Forum on "Desert Sunset". The guy in one of the discussions stated that he liked the Case/IH paint he got from the Case/IH dealer the best. The other paints can be obtained from an automotive paint store.
gary case
01-18-2005 12:17:02
 Re: ji case desert sun paint in reply to C. Amick, 01-18-2005 12:12:25
thanx..... ..... ..... gary case
