Colt tractor blowing hydrostatic fluid
NotMrWizard
01-17-2005 17:58:14
My Colt tractor is blowing hyrdrostatic fluid out of the left-side line, where the steel line connects to the radiator with a short length of rubber hose. When I start it up, the hose swells up. Could it be that the return line is plugged? I'm not sure where or what to look for here. I noticed when I started it today, it didn't "squawk" like it normally does, and it's pretty cold out.
Any help is appreciated.
Neal
01-18-2005 09:14:02
 Re: Colt tractor blowing hydrostatic fluid in reply to NotMrWizard, 01-17-2005 17:58:14
First look at the lines that go into the rear end. I believe that one of them has a screen filter. This is probably plugged.
If this doesnt work then try taking the line off of the other side of the radiator. Check and see if you have flow. If so, then repeat this as you follow the lines back to the transmission.
This is just a blockage of the lines or a valve problem.
If none of this works, email me.
Engineer20
01-18-2005 06:25:18
Try this site. It's all Case and Colt garden tractors....
Link
Hope this helps!
