case 446
Gary S
01-16-2005 17:43:12
The clutch won't stay engaged on my case 446 garden tractor. I use it with a snow blower attachment. Other than that the clutch seems to work fine. How can I correct this?
Klyde
01-16-2005 20:54:36
 Re: case 446 in reply to Gary S, 01-16-2005 17:43:12
Depends if its a "easy adjust" or shim adjust clutch. Shim adjust has a left hand thread bolt and easy adjust has a 1/2" nut and a large 1 3/4" adjuster nut. Shim adjust HAS to be disassembled and shims added to the area between the last cam bearing and the pulley bearing. Be sure when reassembling to offset the cam slots, FRONT HIGH BACK LOW thats the only way they work. Easy adjust, loosen front nut and turn adjuster clockwize to tighten (one flat equals .010") should be set to around that between pulley and clutch facing. Then tighten 1/2" nut to 45ft/lbs. hth
AllanC
01-16-2005 20:08:39
Those clutches are a pain and it is a while since I worked on one. The lever or the slot in the disc is probably worn. You may be able to switch them and make it work. Get a diagram if possible.
