Case 430 advice please.
Chances R
01-16-2005 17:23:17
HELLO
I have always liked the Case 430.
I enjoy tractor rodeos (driving compitition). I was kicking around buying a 430 for the rodeo, but need to figure out what transmission would be best for me. If I remember right there is a shuttle, triple range, and a regular 4 speed. I am needing something with a reverse of 5 to 10 mph or so. What kind of speed will the triple range get in reverse? How about the slow races, are either one good for that. I have also heard that the later 430's are better, I would like to know why that is?
Also a tri cylce front end would not be out of the question. Would it be available in any of the transmission styles?
Any other 430 advice would be welcome!
Thanks
Butch/ OH
01-17-2005 17:08:26
 Re: Case 430 advice please. in reply to Chances R, 01-16-2005 17:23:17
A shuttle trans. would give you the best selection of reverse speeds with a slightly faster reverse in in each of the 8 speeds. I couldn't find a speed chart, but I'm thinking the triple range might not offer any slower speeds than the dual range. You want a mid or late 60's year to get one with hydrasatic power steering. The hydrastatic [only on wide front ends] is much more maneuverable.
mike's600
01-17-2005 16:22:25
I have a 430 case , and a triple range unit if you interested.
Lincoln
01-16-2005 18:35:14
I would think the shuttle transmission would give you the fastest reverse speeds. The 300 with a triple range transmission lists reverse speeds as 1.8, 3.1, and 5.1 mph in the different ranges. I would guess the 430 to be close to that.
