Case Shows
L.C.Gray
01-16-2005 14:49:47
Does anyone know where and when the JICCA National show and the Case Expo will be for 2005?
Engineer20
01-16-2005 15:32:10
 Re: Case Shows in reply to L.C.Gray, 01-16-2005 14:49:47
Found this....
June 16-19, 2005 - Lathrop Antique Car, Tractor, and Engine Association Show hosts the 19th annual J.I. Case Heritage Eagle Expo.
www.lathropantique.com
Casenut
01-16-2005 15:08:48
Found it! The summer convention is at Jacksonville IL. Sept 23-25. Hope that helps you. Casenut
Casenut
01-16-2005 15:05:37
The winter convention is in Wapakoneta OH May 27-29 I am still looking for the summer convention info I will let you know ASAP
Gregg in ohio
01-17-2005 11:55:50
 Re: Case Shows in reply to Casenut, 01-16-2005 15:05:37
Where in wapakoneta is the winter show..im in kenton ohio and its not that far away..thanks gregg wills
Gene Dotson
01-18-2005 04:39:15
 Re: Case Shows in reply to Gregg in ohio, 01-17-2005 11:55:50
Hi Greg; The Auglaize fairgrounds is located off of Rt 33 on Hardin road. I am 28 miles from there just south of Indian lake. I plan to bring a couple trailer loads of tractors. This is a good club and they host some good shows, consignment sales and swap meets... Gene from DeGraff.
L.C.Gray
01-16-2005 17:01:12
I watch each year to see if maybe they are a little further southwest. I caught the Expo in Pawnee a couple of years ago and hope one of them will come closer to home again sometime.
Casenut
01-17-2005 14:55:52
 Re: Case Shows in reply to L.C.Gray, 01-16-2005 17:01:12
To answer Gregs question it is at the Auglaize County Fair Grounds and for L.C. Gray The 2006 spring convention will be at Gray TN. April 21-23 and the 2006 summer convention is at LaSeuer MN. Aug. 25-27 I hope to make it to Minnesota but the other ones are too far for me. Casenut
