case transmission problem model 4690
chrysler513
01-16-2005 06:59:29
dies when let the clutch out and trans is weak ?how big of job is it to repair and whats ball park price to fix it ? i found this tractor it isnt mine they want 1500.00 for it whats it worth has 18.4-34 tires all very nice . thanks for any help
Can't even use my name
01-16-2005 18:08:12
 Re: case transmission problem model 4690 in reply to chrysler513, 01-16-2005 06:59:29
Buy it! We had a 1270 do the same thing. Ended up only being a spool in the valve body hanging up. So simple to fix since the valve body sits right on the side of the tranny in the open. Not sure if that is what is wrong with this tractor or how hard it is to get into the trannys on the 4WD's but on the others it is really not that bad, just a split at the engine.
John Saeli
01-16-2005 10:38:43
Hey Chrysler 513: Ever hear of a Chrysler 413 Flat Head 6??? Are you sure you didn't leave a zero out? The tractor is worth more than that in parts. You would want to rule out all the possibilities of something simple, but if you have to get into it,here is what I did. It is different from the Shop Manual. I removed the engine & dissassembled the Pow'r Shift Unit piece by piece as opposed to a whole unit. That way I could handle it.
JW
01-16-2005 09:34:33
Buy it, the motor is worth that
